Back Bracing for a Martin O http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=16616 |
Author: | Anthony Z [ Thu Mar 27, 2008 9:33 pm ] |
Post subject: | Back Bracing for a Martin O |
I am building a Martin O sized guitar. John Hall and Brad Goodman were kind enough to have sent me specs for the top bracing pattern, I am now in need of the back pattern. If anyone out there has the brace specs and spacing I would really appreciate it if you could provide same. Many thanks, Anthony |
Author: | R W Goodman [ Fri Mar 28, 2008 1:30 am ] |
Post subject: | Re: Back Bracing for a Martin O |
I saved this image from a post on here not long ago. I dont recall whose post it was. I believe it was from a 1937 0-18. Might be helpful to you. Warren |
Author: | TonyKarol [ Fri Mar 28, 2008 7:17 am ] |
here is what I would do AZ..... spacings are from the neck joint for the braces .... 4, 7.25, 10.75 14.75 I am planning to make all my small guitars with the same back braces from now on ... .5 tall, .250 wide. I used to use a .400 wide by .590 tall (still do on larger guits) for the rear two. |
Author: | Anthony Z [ Fri Mar 28, 2008 3:32 pm ] |
Warren, Tony and Todd, thanks for the info. My suspicion is that doing exactly the "Martin" way isn't critical. Tony thanks for the guidance on dimensions as otherwise I would have done the braces in the lower bout area much more "beefy". I've tried to reach John Hall w/o success but suspect I will be just fine with the info provided. Thanks again, Anthony |
Author: | bluescreek [ Fri Mar 28, 2008 8:27 pm ] |
the bracing above is correct. I got a message you tried to get in touch but I couldn't get it to open |
